#447383 09/07/20 11:46 PM
JTJ Offline OP
Hello
I wonder how many panelvans it was made year 1946.
Chevrolet did not make a model called a panel van.
There is a sedan delivery which is on a passenger car chassis or a panel truck which is on a 1/2 or 1 ton trruck chassis.
Hi JTJ
Mr. Schneider is correct in that Chevrolet called your vehicle a "panel truck".
They did however build it in 1/2 ton, 3/4 ton, 1 ton, and even 1-1/2 ton sizes.
1/2 ton was a DP, 3/4 ton a DR (as yours is), 1 ton was a DS, and 1-1/2 ton probably a PJ although I'm not sure on that one.
I found this:
http://home.znet.com/c1937/Prod.htm
It says that for 1946 there were:
2583 first 1946 model and 18614 second 1946 model 1/2 ton panel trucks
4002 3/4 ton panel trucks (yours was 1 of them)
2629 1 ton panel trucks
63 first 1946 model and 1098 second 1946 model 1-1/2 ton panel trucks
This source mentions Ken Kaufmann and David Hayward (both VCCA members I believe) as 2 of his sources, but I'm not sure where his figures for 1946 came from.
If anyone has other, or more accurate information, please correct me.
Hope this helps!
Ole
Ole S Olson
And you will need to scroll about 2/3 of the way down the page to find the info you are looking for.
Ole
Ole S Olson
This:
http://chevy.oldcarmanualproject.com/chevyresto/4660.htm
is an interesting page and is part of this:
http://chevy.oldcarmanualproject.com/chevyresto/46index.htm
which contains a lot of useful and interesting information.
Have fun looking through it!
Ole
Ole S Olson
Just for info. David Hayward passed away in 2012.
And Ken Kaufmann died in January of this year, 2020.
Dale Carter
VCCA #8661
1948 Fleetmaster Convertible
1948 RHD Stylemaster Sedan Delivery
1948 1-Ton Tow Truck
1967 Camaro Coupe
JTJ Offline OP
My is number 3093 so it must be one of the latest produced then...
JTJ Offline OP
Thanks Ole
Glad to be of help!
Remember though that serial numbers in 1946 started with number 1001, so yours should be the 2093rd of that model produced.
Ole
Ole S Olson
