#444494 06/30/20 03:13 PM
Hello,
I just bought a 1948 Fleetmaster coupe that's being shipped from CA and I am gathering information on various parts, planning to replace all fluids when the car finally arrive at my house..Can someone tells me the model number of the 3 speed transmission? Do you pump the fluid out or is there a drain plug? Also what fluid are you using?
Thank you very much
Jacques Grandjean
Everyone is born right handed only the greatest overcome it...
There was only one transmission for passenger cars. It holds 1 1/2 pints of gear oil and the is a filler plug and drain plug,
You can drain the differential by removing the two lower bolts on the cover. It holds 3 1/2 pints.
I have used 85W-140 in my cars for many years.
!0W-30 for motor oil and the lowest octane gas.
Get a shop manual and an owners manual from www.fillingstation.com
Thank you Gene! Do you know the transmission model number? it's easy since there is only one for cars but I want to make sure I can differentiate it from the truck. I already ordered the shop manual.
Jacques Grandjean
They go by case number. The case number for 41-48 is: 591192. The assembly number is: 591187.
Gene is probably taking a nap. bed Agrin
Best,
Thanks Charlie!
Jacques Grandjean
