Owing to the absence of anyone coming to my rescue on the question of lubrication of the vacuum top tubes of the 41 cabriolet and the fact that the 1941 shop manual doesn't seem to cover the topic, I have made a decision based on inference as described below:
a. The knee action shocks use "shock absorber fluid further described in the manual as "shock insolation fluid."
b. The manual indicates that this shock insolation fluid is what is used in the vacuum shift to lubricate the "leathers."
c. I think that the same material is used in the top cylinders, vacuum shift and shocks owing to the notion that all three use neoprene. And none use leather. (Maybe the early vacuum shift and top cylinders did. Don't know.)
d. Using the superior brain-poser of someone who has chosen wisely chosen as to what year among all the old Chevrolets is supremely best (1941, of course) I have come to the conclusion that if this shocks and the vacuum assist may use shock absorber/insulating fluid then the stinkin' top cylinders can too.
e. I am going to wipe/clean out the top cylinders and coat the walls and the neoprene surfaces with shock fluid.
Question before I do this: What do you all think of my reasoning? (Despite a demonstrated total lack a favorable choosing for your year to be stuck with, 37 and 38ers positive (dig deep) input is welcome.)
Chipper, Mike and Gene, et al: I think you know some good advice on this issue but for whatever reason have left me to founder in trouble waters! What say ye? Stinkers!
Thanks a heap for any advice.
Charlie
