I need more advice guys. In my attempt to remove the trans in my '31 coupe, I've removed the torque tube, u-joint, the shifter and the bolts attaching the trans to the bell housing, but the trans will not come any further than one half inch back from the bell housing. I want to remove it, because I see galling on the some of the gears. My guess from looking at the wear patterns is that the trans would be noisy in 1st and 2nd gears. After removal I will be able to check for bushing and bearing wear also. I didn't have the opportunity to drive this car, since it was in pieces when I bought it, so I want to be thorough as I go through each part of the chassis. Also, I need a source for gears. I see bushings, bearings and gaskets in the Filling Station Catalogue, but no gears. Thanks in advance for your thoughts. This web site makes my hobby a whole lot easier.
