Posts: 91 |
I have performed a search for water pumps and to no avail. It seems somewhere on this site a discussion was held on the issue of replacing the original packing type water pump with a modern version that did not use packing. My water pump is trash. Is there a source for a modern water pump without the packing, and possibly with an enclosed impeller that would render the use of the baffle obsolete? Thank you. Steve
I don't remember of ever seeing anything about a ball bearing pump for pre-1937....In one thread I stated that the original 1937-early 1938 pumps had bushings and after a short while only the ball bearing pump was used for replacement.Perhaps thats what your think of.
