#434363 11/16/19 06:08 PM
tye Offline OP
This may be pretty ridiculous but where is the wiper switch in 48 Stylemaster!? I see heat and defrost and that’s it! (Not gonna be my last ridiculous question either haha)
tye #434364 11/16/19 06:17 PM
On top of the instrument panel above the speedometer next to the windshield glass.
Chev Nut #434378 11/16/19 08:52 PM
tye Offline OP
Well that would explain why there is a small metal circle there, almost like a pancake cap. I can't find anything online to order.....anyone know where to get one? (Is it as simple as that or not so much with the vacuum system that I do not fully understand yet)
tye #434384 11/16/19 11:50 PM
And it is not electric.
tye #434397 11/17/19 11:45 AM
Try Vintage Chevy Parts 760-723-5134. He has a supply of unobtaineum. He had a '53 selector lever bushing for my car that no one else had. Not cheap.
Keith Knox #434417 11/17/19 05:22 PM
I wonder if someone switched out the motor to electric
Didn't think of that. Tye is there vacuum hose running from the intake manifold to the firewall? That would be the wiper motor vacuum hose.
Keith Knox #434453 11/18/19 01:09 PM
tye Offline OP
So there is just the hose coming out of the back and into the firewall. The 'motor' is there, just looks like it is missing the parts to engage it....if that makes sense. Whatever goes from the 'motor' through the tiny hole in dash is missing. I found two "switches" in the glove box. One is shiny plastic and one is ivory'ish plastic.
tye #434462 11/18/19 04:49 PM
I believe the missing "switch" has a short arm underneath the knob. It is attached to a linkage which moves a vacuum switch on the motor.
old216 #434466 11/18/19 06:18 PM
This is what the switch looks like on my 41.
tye #434467 11/18/19 06:25 PM
The wiper switch on my 47 and 48 that bought this fall the has 3 vacuum ports, one goes to the intake manifold and 2 go to the wiper motor. My 41 was like the one Mike’s picture.
dens41 #434468 11/18/19 06:28 PM
[Linked Image from pic100.picturetrail.com]
This is what a '48 looks like.
Knob
Click on Knob to see the correct knob.
Russell #38868
'48 4 door Fleetline
tye #434477 11/18/19 09:44 PM
My apologies, I guess things really advanced from 1938 to 1948. That is interesting because my 1951 truck wiper setup is very similar to my 38 Master.
tye #434482 11/18/19 10:32 PM
I guess the best way is to pull the motor and see how it should be activated? An external switch? Two vacuum ports?
Tye?
tye #434521 11/19/19 07:02 PM
tye Offline OP
Sorry for the delay.....the picture that Mike Butler attached IS IT!!! Those pieces are in the glove box.....will it be hard to figure out where it goes, once I am upside down and turned around under the dash?? HAHAHA Is that all there is or am I still missing a piece? By the way how d o I post a pic??
tye #434524 11/19/19 07:38 PM
If it was me, I'd remove the motor (the harder to reach screw should just be a slot...so don't need to remove that screw all the way). Then put the switch in. Inspect the motor to figure out how the switch arm activates the switch on the motor, then put the motor back in.
Next....figure out that the motor needs lubricated/rebuilt.
Lubrication options include introducing ATF into the motor by inserting the motor's vacuum line into ATF while cycling the wiper blades by hand. Alternatively, you can soak the whole thing in ATF for a few days.
I tried both of those and it didn't resolve my problem. Wiperman rebuilt mine and it works like a champ.
tye #434525 11/19/19 07:39 PM
to post a picture, click the USE FULL EDTOR button on the bottom.
you can use the INSERT IMAGE LINK icon if the picture is on the internet,
or you can use the ATTACHEMTN MANAGER link down below if the picture is on your computer.
VCCA Member 51121
modiol #434527 11/19/19 08:00 PM
And you need to be a recognized vcca member in the forum
tye #434539 11/19/19 10:38 PM
Yes, I suspect that is because it is not the switch for a '42-'48 wiper motor. Now if someone installed a different motor, then maybe.
Russell #38868
tye #434553 11/20/19 09:49 AM
I think Russ is right.
Here is the parts book. I googled the part number 4132267 and came up with
https://autopartsobsolete.com/1942-...dshield-wiper-switch-nos-gm-4132267.html
The arm looks shorter than the one in Mike's photo above.
Scott, 4132267 is the number for the knob. The control switch is 4131075. That ad in your link is wrong!
https://www.google.com/search?q=413...DqQQ9QEwA3oECAoQDA#imgrc=hQmWZzGu2zD48M:
Russell #38868
tye #434568 11/20/19 02:38 PM
Thanks for keeping me honest Rus.
Are the two ports on the switch towards the motor for slow/fast?
https://vccachat.org/ubbthreads.php/topics/255408/Re:_Wiper_Motor_(Vacuum)_1948_#Post255408
Might want to read this old post about the '42-'48 wiper motor.
Russell #38868
ruscar #434693 11/22/19 12:15 PM
tye Offline OP
Ok let me get it out and I’ll get you an update! Thanks again
