Sorry for the delay.....the picture that Mike Butler attached IS IT!!! Those pieces are in the glove box.....will it be hard to figure out where it goes, once I am upside down and turned around under the dash?? HAHAHA Is that all there is or am I still missing a piece? By the way how d o I post a pic??
If it was me, I'd remove the motor (the harder to reach screw should just be a slot...so don't need to remove that screw all the way). Then put the switch in. Inspect the motor to figure out how the switch arm activates the switch on the motor, then put the motor back in.
Next....figure out that the motor needs lubricated/rebuilt.
Lubrication options include introducing ATF into the motor by inserting the motor's vacuum line into ATF while cycling the wiper blades by hand. Alternatively, you can soak the whole thing in ATF for a few days.
I tried both of those and it didn't resolve my problem. Wiperman rebuilt mine and it works like a champ.
