#42842 03/15/04 10:52 PM
First, Thanks to d2d2's posting of Casting Numbers in Teck Talk I was able to find out the following. The block number on my car is 836409 indicating it's a '31. The head number is 835503 indicating it's a '29. Will that cause a running or idleing problem? It seemed to work OK when I ran it 30 years ago and thought it was the carbruator that caused it to idle a little rough. Hate to put it back together if it wouldn't run just right as I have an other head #836273 indicating it's a '31. This came off a block # 836573 indicating it's a '32. Would like to put the '29 back on and try it as the '31 would have to be completley redid. Not much of a problem to change heads and not even sure the '31 isn't cracked or wraped. Thanks. Oh My Gosh, I can't get the spell check to work.
#42843 03/15/04 11:01 PM
The '29 head should work ok on the '31 block. The only difference I can recall is that the '29 has smaller valves and a different location of the temp sensor.
If you have old Chevrolets, other old Chevrolets will find out where you live.
#42844 03/17/04 10:33 PM
Thanks d2d2, Just checked my '31 head and found out one rised valve holder is broken off so will check out one more I have on an old motor. dance Hate to scrap an old head but I don't think it can be repaired. :confused:
#42845 03/17/04 10:52 PM
Are you talking about a valve guide? If so, no problem since those can be replaced. laugh laugh laugh
#42846 03/18/04 01:11 AM
:o Well, I guess that's what maybe you would call it and I didn't realize they could be replaced. :arrow: Will check it out. Thanks for the tip. Now I'll tip one. drink
#42847 03/18/04 11:55 AM
Sure! Valve guides can be replaced and you can buy them brand new! yipp laugh laugh laugh
#42848 03/18/04 01:59 PM
Great, Will take it in and see what the machine shop says. dance Same place I'll have it boiled out at. :cool2:
