Terry,
Group number 0683 in my 29-50 parts book lists the following:
38-39 ALL PASS (casting No. 838669) Part number: 602955.
38-47 ALL COMM. and UTILITY (casting no. 839257 (w/35/8 lever slot) Part number 3847361.
NOTE: When installing 3847361 on 1938-39 jobs discard fork ball supt. and assemble ball to housing.
The book used didn't mention LH, 1791 or 452 cast numbers although I expect GM would be on there somewhere.
Note from me: The clutch cover bolts to the pressure plate and the bell housing bolts to the rear of the block and therefore covers and protects the whole clutch assembly. I don't remember seeing a number on the covers but they are the same except for 9 inch pressure plate, disc and flywheel. The covers are the same for all pass from 38-50 for all pass (6 bolt) and all pass and all comm and util (exc. 1/2 ton) and all pass and 1/2 ton comm (hvy duty.(9 - bolt))
Best,
Charlie
