#422242 03/09/19 11:37 AM
Hello folks, my 41 Special Deluxe 5 Passenger Coupe has always sat a little low in the front since I bought it in 2015 and was wondering if the front springs need replacing. The front shocks have been replaced 3 years ago and it drives down the road fine.
Would anyone have the specifications for how to check for the proper body ground clearance for front and rear. Thank you.
John
The instructions are on page 68 of the 1941 shop manual. Unfortunatly it was done with a special gauge.
When on a level surface and viewing from about 20 feet away the side the top of the tire should be about even with the top of the wheel opening.
John,
There were three specifications of springs for the front and two types for the rear. (this is using a 1929 - 50 Chevrolet Parts Book)
The fronts:
1939-41 (except JB & KB) 1310 lb. tension had sire diameter of .576-.580 with white paint down the length at the same arc of the spring) Part # 3653059
1940-48 (/exc. KB) 1600 lb. tension and had a wire diameter of .608 - 612. Paint was blue. Part # 5246233 (I have seen that these were for heavy duty.
1940 - 48 (exc. KB) 1375 lb. tension and wire diameter of .585 - .589) Paint was green. Part # 3664086 (I don't have a clue as to why they had this size)
The Rears:
1940 - 50 (1941 16 inch wheels, heavy duty, covered) Part # 605383
1940 - 50 All with covers Part # 605374
Over time the springs both front and rear will loose tension. Two remedies come to mine for the front. A spacer that can be inserted in the wire coiled space or a washer in the bottom of the A-frame or replacing the spring. The stronger tension and wire diameter will tend to keep the height higher then a lesser tension ones with smaller wire ones will. That is obvious.
The rears ones may see some longer use by using longer reach shackles. The heavy duty 8 leaf springs will tend to take longer to sag below a suitable level. But, as in the front they may initially seem raise the car a bit too high.
The basic Chevrolet parts places have replacements. You may also look up the wire companies and have them cut you a set at a lower price. You'll be able to specify the diameter wire you want.I'm getting a little out of my area here.
A 1941 or other year parts book may list different information but basically I doubt the part numbers will change.
Covered rear springs are getting hard to get.
Good luck,
BTW: There is one other thing in the 1941 that has a heavy duty application and that is the clutch assembly from and including the fly-wheel, disc, pressure plate to the cover with spring. All heavy duty.
Great details from Charlie.
The key fact is that all springs (coil or leaf) will settle over time. The load capacity and the spring rate do not change.
How much will springs settle?
Heavy duty spings from Chevrolet DID NOT make the car sit higher. The spring wire was thicker and the actual spring shorter so the riding height would be the same. They just made the ride stiffer and would deflect less under load.
The front coil springs almost never settled any noticable amount like the leaf springs did.
Gene makes a good point about the words "heavy duty springs".
In any coil spring design there are multiple variables: wire diameter, coil diameter, number of coils, and free length. The result of these variables is load capacity, spring rate, and height under normal load.
Thanks guys for the better knowledge.
Seems I learn something almost every day and I am grateful for that. dance
Best,
Thanks everyone for your replies. So from your info I think the front is sitting correct. It is the rear that is sitting a little high. I will try to post a picture.
John
Russell #38868
'48 4 door Fleetline
