Posts: 131 |
I’m the one with the 32 Chevy Racer. The engine and rear end are completely stock. On the hiway I keep it below 3500 rpm to save the rod bearings. About 50 - 55 mph. Now it only weighs 2100lbs. What are my options to lower the rpm for a higher speed? Overdrive unit, or different rear gear set? Availability, practicality, price. Thanks for your thoughts, Norm
50 to 55 MPH with the stock1932 4.1 rearend is about 2500-2600 RPM ...3500 RPM would be 70MPH and on a 1932 good bey rods. An overdrive would reduce engine speed the most.
Posts: 3,292 |
I’m the one with the 32 Chevy Racer. The engine and rear end are completely stock. On the hiway I keep it below 3500 rpm to save the rod bearings. About 50 - 55 mph. Now it only weighs 2100lbs. What are my options to lower the rpm for a higher speed? Overdrive unit, or different rear gear set? Availability, practicality, price. Thanks for your thoughts, Norm I would consider purchasing a halibrand quick change rear end and getting the right width. They are available brand new and used. Easily convert the mounting to the springs on the rear like a stock one. But you would want to convert it to open drive with exposed driveshaft. Take the cover off the rear and flip the gears to get a different ratio. Converting the rear end to mechanical brakes is another obstacle to overcome. mike lynch
Posts: 131 |
OK, 1. Are there any of these Larry Jackson gears out there. Expected Cost? 2. Is there an overdrive add-on available? If so, a name or source? In my best imagination, it would be a replacement for the free wheeling unit. Regards
Are there any of these Larry Jackson gears out there. Expected Cost? Probably not. A lot of guys are looking for those gear sets since they haven't been available for a long time. I believe that when the gear sets were available Larry was selling them for around $1,100 each.
Posts: 656 Likes: 3
Posts: 656 Likes: 3 |
A Mitchell overdrive wold be nice, but you would have to figure out the machine work and installation yourself (they only support the toque tube unit on certain Fords). There is also the former Lloyd Young Overdrive (borg warner conversion). Lloyd has passed on, but his machinist Glen has taken over, so these conversions can still be done. Popular in the Buick crowd. http://forums.aaca.org/topic/304816...?page=5&tab=comments#comment-1749725Or, you could go to GearVendors. I spoke with Larry Jackson about a year ago. He said he wasn't making any more gears.
Posts: 3,292 |
OK, 1. Are there any of these Larry Jackson gears out there. Expected Cost? 2. Is there an overdrive add-on available? If so, a name or source? In my best imagination, it would be a replacement for the free wheeling unit. Regards Try an advert in HEMMINGS MOTOR NEWS appropriate section ,??? , " WANTED , BLAH BLAH , CALL ME COLLECT IF YOU HAVE ONE " paying XXXXX $. mike
Posts: 131 |
Junkyard Dog, I wonder if my tack and or speedometer is reading wrong? At 3,000 rpm my speedometer is showing 53 mph. The original car was just a coupe. The speedometer is stock 32 Chevy. The tach is electronic, I think for a diesel because I selected it because it tops out at 4,000 rpm. Thanks
