Posts: 188 |
Can some one recommend a good locksmith, have a locking handle with out a key. thank you dave
Posts: 188 |
Will try Jarvis, thank you, if anyone else has locksmith please advise. thanks
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Many local locksmiths can make a key either from the code number or by profiling the lock. I have been told that the B&S key codes may be under Harley Davidson not Chevrolet. Code numbers are supposedly the same. I have a code book for late 20s to '34 if your locksmith can find the code.
Posts: 188 |
Thanks Have a trunk handle without the key, the code is very clear Also a trunk handle with matching key, however it will not move. Thanks Dave
