Posts: 2 |
I have acquired a '56 Chev pickup with a very tired 235 six with a four speed. The quoted cost to rebuild it is horrible and all the rebuilders advise installing a small block V8. I have a question regarding motor mounts for the V8. I know there are kits available for the front mounts but what about the rears? The six has a rear mount on the engine with no mount on the transmission. The small blocks I've seen use the transmission as the rear engine mount. Will I have to relocate the rear crossmember?
Mr Bill
Posts: 382 |
AFIK the early small blocks used the donut mounts at the very front of the engine and the rear mounts were on the bellhousing.
Posts: 2 |
Thanks for your help George, I appreciate it.
Posts: 11,162 |
Amos, you will need to either fab up a crossmember or buy one from a vendor specializeing in engine upgrades from a six to a Small block V/8. Those of us here that hold to original values in regards to the old six cylinder Chevrolets do have a harder time finding rebuilders and overhaul parts but as one of my friends said :
"It is worth ever bit of it, to keep my car a six cylinder!"
Posts: 382 |
MrMack,
Wouldn't he only need to fab up a crossmember if he went with a 58 or later V8 engine? The 265 was an option on trucks in 1956, so stock parts should work, or am I missing something? I do realize that the V8 is shorter, but I don't remember having to do anything special to replace the six with the early V8.
Posts: 865 |
The V/8 truck engine used the same type front motor mounts as the 6 cyl but the V/8 mounting studs were different ( shorter or longer, I don't remember which). If you plan to use the same transmission find you a V/8 truck bell housing and use the original mounts. The two bottom trans. bolts will need to be mounted from inside the bell housing.
DD
Posts: 11,162 |
Yep, I was wrong about the crossmember. Probably all you will need is a V/8 bell housing, & the original V/8 engine mounting bracket and maybe change the starter to a key or button starting switch?
