Posts: 188 |
during the initial start up of engine, the carter updraft carb started leaking at the screw in bottom of the bowl. The screw was tight, did not want to over tighten. please advise of any suggestions. thank you Dave
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
was there a washer on the screw ?? Bowl w/ Washer & ScrewBowl Removedlook at the screw in the top of the picture above carburetor below the wrench, see the reddish color washer.
Posts: 188 |
Thank You both for the assistance. Dave
Posts: 188 |
have tried two different sealants on gasket, is there a specific type / brand to use?? there is a slow drip
PS, She did start !!!!! thanks Dave
is the gasket between the bowl and the carb correct ?? is the bowl fully seating ?? is the bowl FLAT and now bowed or concave/ convex ??
the bowl should be flat, and seat fully, then the fiber gasket should seat against the bowl, and then the screw should hold it all tight !!
can you spin or move the bowl when assembled ??
make sure the Screw fully seats and screws into the carb. try to screw it in with out the bowl on and see if it screws in all the way.
Posts: 188 |
Posts: 188 |
So the screw was not tight enough on the bottom of the bowl, good call, was afraid to over tighten.
Now there is gas leaking out the top of the bowl, checked the float and needle valve. any suggestions?? thank You
Posts: 301 |
When you checked the float do you meant the float level?
"Never give up" Louis Chevrolet
Posts: 188 |
Yes checked the float level also checked it to make sure the float did not fill up with gas.
Ok will check the needle. thank you
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
If you don't find a problem with the needle/seat then check to be sure the internal float bowl vent is clear. If the vent passage (inside the bowl to inside the throat) is plugged the needle/seat will not completely seat and gas will over flow. If that is okay then check the float to make sure it is not rubbing against the center (well) of the body or the side of the float bowl.
Posts: 188 |
Thank You one of the gentlemen helping me asked "is there a possibility that there is too much flow from the fuel pump???" Dave
If you are using an original mechanical fuel pump then it is not likely that the problem is too much fuel pressure. However, if using an electrical pump it is highly likely unless you have a pressure regulator. The float/needle/seat combination is not designed for the pressure of many available electric pumps.
Posts: 188 |
Chipper, Thank You Using the original mechanical fuel pump. Thanks Dave
Posts: 188 |
If you don't find a problem with the needle/seat then check to be sure the internal float bowl vent is clear. If the vent passage (inside the bowl to inside the throat) is plugged the needle/seat will not completely seat and gas will over flow. If that is okay then check the float to make sure it is not rubbing against the center (well) of the body or the side of the float bowl. Chipper could you advise as to where the internal bowl vent is located, for some reason cannot see it. thank you Dave
Posts: 188 |
Glad you found it. Hard to describe where it is located without actually looking at a carb. Didn't have time to actually look before you found it.
The '29-'31 Carter carbs rarely have that passage plugged. The earlier 4-cylinder carbs have it much more often as it vents to the outside of the casting.
Posts: 188 |
Had a spare carb and used it to locate the vent. The vent on the car carb was not plugged.
the issue turned out to be the connector that the fuel line attaches to was not snug on the carb and gas was going down and around bowl. Snugged it up and fired up with no drips.
appreciate all the assistance. First time in about 55 years, it was driven.......
Glad you got it sorted (tribute to Aussies and Brits). Can only imagine the joy in getting it back on the road after such a long rest.
