Posts: 1,869 |
The other day I tried a section of road that had just been repaved. I was blistering along at 55 when the amp gauge centered itself. I thought that that fancy diode cutout had just done its job. After a while it started to show a discharge. I remembered the last time I had charging issues the resistor on the switch had burned out. It was that again. Any ideas?
Posts: 1,869 |
It was right at the top if I remember well.
Posts: 1,869 |
I'll check that again. Is it possible that third brush has moved?
Posts: 1,869 |
Towards the block is down right?
Posts: 1,869 |
I think I've got it. This is at fast idle with the choke on.
Driving down the road at 55, the max. output should be about 10 amps. So, what did you do to correct the issue.....re-adjust the third brush?
Posts: 1,869 |
Posts: 1,869 |
It is and it was. I guess I hadn't set it low enough the last time.
Posts: 1,869 |
Found out today that this episode had boiled the battery, or perhaps it had been boiling for a while. Anyhow with a new battery, charging at 10 amps I should make it through the summer OK.
