Posts: 194 |
Does anyone know the factory location for the ground strap?
Posts: 2,306 |
Are you referring to the ground strap on the battery? If you are it attaches to the bolt hole on the far left of the flywheel housing. Good luck, Mike
Posts: 194 |
Thanks Mike I thought that is where it went. Just wanted to make sure.
