Posts: 35 |
I'm going to do my best to describe this sand I've attached a picture of exactly what I'm talking about.
Where the "sleeve" fits over the top of the starter switch... As you can see in the picture, I've just got a bolt running through, and that bolt is what makes contact with the top of the starter switch.
Am I missing a piece? I get the feeling that's not how they would have done things originally. [img]https://1drv.ms/f/s!AiH8qT9E4JoRzmwkM9s6q-jLpgFw[/img]
1931 5-Window Coupe # 1,406 of 28,379
Posts: 35 |
Yea I figured a cotter pin would make more sense. Just need to get one. Is there anything between the cotter pin and top of the switch though?
The problem I have is that the hole is drilled too far back/the bolt bends and then pushing the starter pedal doesn't depress the switch enough to make a connection.
Posts: 35 |
Ah Ha! Yea I don't have that piece...
I will just have to go get a cotter pin and a spring.
Thank you much!
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
here is what it looks like on my 1929 1929 StarterMine has a Spring, Washer, and the Pin Spring (835785) sets against the Washer (835698), Washer sets against the end of the starter Link (835779), Also there is a Pin & Washer holding the Starter Link (835779) to the Bracket Assembly (356551) Per the 1929-30 MPL Pin, Starting Motor Lever to Pedal Link(1/4 Dia x 23/32" Long under Head).....356905 Spring, Starting Motor Pedal Link.............................................835785 Washer, Starting Motor Pedal Link Anti-Rattle.................................835698
Bracket Assembly, Starter Pedal...............................................356551 Link, Starting Motor Lever to Pedal...........................................835779 ...Rod End Pin (1/4 Dia x 51/64 Long under Head)..............................114783 ...Plain Washer (1/4) 106261The Bracket was same on 1929-30, and then different one used on 1931-32. Looks like washer was only used on 1929. based on 1929-1930 MPL and 1929-1932 MPL side by side. can get you specs on the spring if interested, since my transmission is torn down as i am working on it.
Posts: 35 |
Thanks, BearsFan315, and happy birthday!
Yes, if you don't mind the specs on that spring would be handy.
