Me again,
My speedometer inner cable has sheered off at the transmission.
Is there something likely causing this condition? I am hesitant to replace it for $45 and have it break again. Filling Station is out of their $35 ones.
Thanks,
Jim
Jim Barnhart
Temple City, California
Link to Jim's Chevy
1929 Sedan
1969 Corvette Coupe
Your inner cable would have run dry and seized or your speedometer itself has seized thus causing the cable to break. I would suggest removing the speedometer and testing it to see if it still turns freely.
Thanks JYD. will do.
Jim Barnhart
Link to Jim's Chevy
1929 Sedan
1969 Corvette Coupe
Yep, the speedometer seems to be frozen up.
Jim Barnhart
Link to Jim's Chevy
1929 Sedan
1969 Corvette Coupe
Yep, a frozen speedometer was definitely the symptom of your issue.
You must obtain a new/used speedometer that works before you replace the cable. Otherwise you will be replacing cable #2.
Agrin devil
Rebuilt cable is on its way. My odometer was locked (2 spindles) so I'm going to use a working used one I got from eBay a while back.
How does one lubricate the speedometer/odometer and the cable?
Jim Barnhart
Link to Jim's Chevy
1929 Sedan
1969 Corvette Coupe
Do a search. We have had numerous discussions recently on lubricating the speedometer and the cable.
