Posts: 584 |
The windshield on my '31 coach has never rolled up or down. The handle spins freely as thought it isn't contacting anything. I plan to attack this problem soon as the humid summers here in TN NEED that extra ventilation.
I have searched the threads and have not found any pictures of this process. I would like to see what I'm getting into. The fabric is original and I don't want to damage it because of areas that have nails that I am unaware of. I assume the handle is removed the same way that the door handles are, with the clip that is pushed off with a door-handle-removal tool.
Any help, or links to discussions I may have missed with step by step instructions on this process would be greatly appreciated.
Thanks, Brandon
Youth is wasted on the young
Posts: 558 |
Hi Brandon, In this hot, humid weather the operating front windshield is a real plus. On my '30 coupe, the regulator board cover is held in place by four bolts, one at each corner. There is also a trim board nailed over the upper part of the regulator cover board. I removed the trim board by prying it off with a large flat tip screwdriver. Here is a link to the Fisher Body Service Manual which sort of describes and shows the windshield regulator assembly: http://chevy.oldcarmanualproject.com/fisher/2632fbsm/2631fbsm107.htmlIt's been nearly 10 years since I've worked on this assembly, so my memory of how it looks is not so good anymore. Happy Motoring, Dan
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
The handle is held on by the same clip as the door handle and window crank. The gears are originally die-cast and likely need to be replaced. Kits are available from the Filling Station part number FS-206. Probably others as well.
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
just a side note there is a CORE charge to return your original crank shaft or pay the core charge. like $35
Posts: 584 |
Thanks everyone. Using the information I gathered on how it works and looking at some pictures that Sal emailed me I was at least able to get the windshield up by raising it by hand after turning the handle all the way the correct direction. For now I've got a small piece of wood I made with a channel for the glass holding it up. Since I'm only able to use limited funds to slowly fix the problems on this car I think I'll move this one down the list for now and move on to some other issues firs, given how expensive the gear mechanism is (if you can't find a good used one).
I'll come back to this at a later date and when I do I'll post pictures of the progress.
Thanks, Brandon
