#369345 05/29/16 05:35 PM
Shorty Offline OP
Went for a ride the other day and car was charging just fine. Some where along the way it quit. Looking for suggestions as to where to start checking first.
Shorty #369347 05/29/16 06:22 PM
Check the generator and the voltage regulator. There is a test that you can perform that will tell you if the problem is either the generator or the voltage regulator. Check your shop manual for the test procedure.
Shorty #369349 05/29/16 06:29 PM
Shorty,
OK, check the following:
a. Fan belt
b. Hit the generator with a good sized hammer while engine is running. At the same time check the battery charge meter in the dash.
c. Pull the generator, check the brushes.
d. If brushes are bad, go to NAPA or some other parts place and get a new set.
e. Clean commutator using sandpaper, if nothing else.
f. If it has a Fulton, remove it.
There are other things to do but none come to mind right now. Others will have suggestions also.
Good luck,
Once you determine if the issue is your regulator (likely) or generator, you may want to pick up a spare voltage regulator to take on longer trips. When they go bad, they can ruin a road trip in a hurry. You can get a 'service replacement' regulator at O'Reilly or Napa for under $40.
Generator overhaul isn't bad either. Brushes and a clean up of the commutator is usually all they need unless its pretty beat up inside.
Good luck!
-Daryl Scott #45848
1947 Chevrolet Fleetline Sportmaster Sedan
1976 Chevrolet C20 Fleetside
