Posts: 125 |
Hello everyone , I have a 454 cu in engine in my truck & can't get it to fire; I have voltage on both sides of the resister & both posts on coil are hot as is the high tension coil wire, but I'm getting no fire to the points; What could be the problem? Thx for your help.
If we knew the year we would be 1 up on the answer.
Posts: 125 |
I was told that it is a 1971.
Internal break in the wire runing from the coil to the points?
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Do you have voltage to the positive arm on the points when they are open? If not then track back to find the problem.
