Posts: 67 |
I want to run my GPS on the 6 Volt car battery with a direct hookup. Typically, they are about 5 volts. Other than adding a fuse, should I need to do anything else?
Posts: 935 Likes: 12
Posts: 935 Likes: 12 |
I use my booster box that has a power outlet built in to run my CB and/or GPS
Posts: 292 |
You might want to consider a 6v to 12v converter they are easy to find. Al
Posts: 828 Likes: 6
Posts: 828 Likes: 6 |
I would use a fuse, my GPS works fine on 6 volts in my 28 and 49.
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
dens41, You say your GPS works fine on 6V. What brand GPS do you have?
Joined VCCA June 1, 1961
Posts: 828 Likes: 6
Thanks, I tried my Garman in our '40 and it worked.
Posts: 1,019 Likes: 3
Posts: 1,019 Likes: 3 |
I put a 6 volt to 12 volt converter ($100) in my car because I thought I needed it to charge my GPS (Garmin) and my cell phone. I think I'll take a closer look at weather I need it or not, it tends to make a static noise when I'm at high speed (55mph).
In the past I have used a sealed 12V battery for my CB and GPS. Worked fine all day and would put it on charge at night. One battery has lasted about five years.
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
In the past I have used a sealed 12V battery for my CB and GPS. Worked fine all day and would put it on charge at night. One battery has lasted about five years. I've seen 6 volt to 12 volt boosters. Is that a reliable option ?
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
I bought a 6-12v step up for my '38 in order to use my GPS. I read recently on another board that a 12v GPS will work just fine on 6v. I've not tried that though. I bought my step up on ebay for $60. This is the one I use. The listing says Porsche or VW but it works with any 6v negative ground system.
I bought a 6-12v step up for my '38 in order to use my GPS. I read recently on another board that a 12v GPS will work just fine on 6v. I've not tried that though. I bought my step up on ebay for $60. This is the one I use. The listing says Porsche or VW but it works with any 6v negative ground system. Thanks, Tiny. An easy hook up with instructions ?
If I can do it anyone can.
If I can do it anyone can. OK, LOL, thanks.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Tiny, The thing is that if you or any other 37/38ers were using your GPS to travel for some reasonable distance, say to the next county, the place would have changed by the time you got there. Try taking the missus along and give her a road map. Teach her how to fold it, too. Things change nowadays so fast, you're gonna be lost anyway. Charlie BTW: Take a picnic lunch with you. You'll get get hungry before you get there. And stop at every rest stop. They're better than the woods. Chiggers, red bugs, and all.
Posts: 828 Likes: 6
I use the gps in my 28 because the speedo is 10 - 15 mph slow and they have so much power I don't want speeding tickets.
If I can do it anyone can. I look at it this way, Tiny. If I hook up the GPS, as directed, and its wrong, the fire dept. will find me, due to the size of the flames, and not the GPS.
Posts: 99 |
I wired up a USB outlet to run off the 6V battery. I have hidden it in the glovebox for now and pull it out when needed. This allows me to use any USB charging cord in my outlet to charge my phone, GPS or passengers phone.
USB outlets are made to provide 5 volts out. The only caveat for some devices (i.e. iphone) is that the device also needs to see 1.5 volts on one other pin - so I have a couple of resistors in there to drop the voltage to that pin. I have wired it directly to my battery with a switch to prevent battery drain when the vehicle is off. You could wire after ignition, but I wanted to option of charging phone with the truck off.
If folks were interested I would be glad to draw a schematic and upload it here. Parts cost me less than $10 total.
Posts: 1,513 |
I think that information would be good to have. If you can post it on this forum.
Why can't you use the 6v cigarette lighter source for your GPS? Charlie
Hello Charlie,
I know this off topic, but in response to your comment about '37/'38's, I traveled to Halogen, N.J., on Memorial Day weekend in my '37 Master DeLuxe, from Massachusetts and the trip took 5 hours @ 55mph. I was assured, from relatives, that other than weather / temps that nothing had changed.
Your last long trip in your '41/'42 was when ?? :-{)
Dave, I think you got me there. It was back in 1975. I was much more spry then. I was only 41 or so and didn't think any amount of roas trouble would concern me. And, it didn't. Now, I am just as adventerous but not as stupid. Best, Charlie
Posts: 1,113 Likes: 1
Posts: 1,113 Likes: 1 |
Bob, If you don't use your 6 volt cigarette lighter, I would wire in the converter in that circuit and hide it behind the dash. That way you can plug your GPS cord right in. The lighter is a one wire circuit that uses the dash for a ground.
Rick
One more note on this....I see others are saying they've used their 12v devices like cell phones and GPS at 6 volts without problem. Knowing the current is much higher at 6 vs 12volts, I would be reluctant to just plug it in, IMHO..I would spend the money and buy a converter/adapter rather than risk damaging my phone or Garmin unit. But that's just me. Cheers from Sunny So. Cal!!!
Rick
