#364241 03/10/16 07:43 PM
Honer Offline OP
I have tried to twist and some pry to get top off of the coil so I can remove wire and replace grommet. Don't want to tear it up. Any help would be greatful.
Thanks The Honer
Honer #364243 03/10/16 08:00 PM
Eli Offline
You may have an aftermarket piece, but I think they followed the same design. If you send me your email address, I will forward a pdf of the Delco instruction sheet, better job than I can do explaining.
1937 Master DeLuxe Business Coupe
1954 3100 5-Window
1954 Corvette
Honer #364244 03/10/16 08:09 PM
Eli Offline
1954 3100 5-Window
1954 Corvette
Eli #364253 03/10/16 10:55 PM
Honer Offline OP
Got it thanks will try tomorrow. I have the 1937 Chevy Repair manual why is that not in there anyway thanks again.
The Honer
Honer #364256 03/11/16 06:16 AM
I was never able to find the release tab and ended up destroying the coil getting mine off. Once you get it off do yourself a favor and use a Dremel tool to grind down the nub on the inside of the cap that the tab locks to. In the future all you'll have to do is twist & remove the cap without having to fuss with finding and releasing the tab.
Tiny #364381 03/12/16 07:48 PM
Honer Offline OP
You are right I broke .015 feeler gages a number of times. Once I got it off I don't think something that thin would move it out of the way. Love my Chevys but that is dumb.
The Honer
