The first photo is the correct shaft for spiral cut gears, if used with the original pinion gear with a shoulder for the ball bearing (part # 24762 in the Combined Parts List Four Ninety and Superior Models, effective on and after February 1st, 1924) and the special woodruff key with a low profile (24049).
The taper length is approximately 51,5 mm.
The second photo has a rear end taper that fits the original pinion gear with straight cut gears (H 94?), but it can also be fitted with an aftermarket pinion gear with spiral cut gears. A couple of vendors offered a conversion set, including ring and pinion gears and the "Differential Ball Thrust Bearing" (part # H 1022). I am quite certain that these conversion sets also fitted Ford Model T. I have seen parts or descriptions of sets with both 9:33 and 9:34 gear ratios.
For both shafts the pinion rear nut must be of the low-profile kind, part # H 669.
I am sorry to hear that your ring and pinion gears are "destroyed". If so, maybe you can have some help from my
thread on drive shaft,ring and pinion gears and rear axle.
