Barney Offline OP
I'm thinking that it's time to replace the leaking,worn out manual gear on the 55 Chev with a rebuilt manual one.The Shop Manual is very good at explain the procedure but I can't figure out if I need to remove the shifter tube and mast jacket first.Or can I take off steering wheel and pull the gear and shaft out from underneath after removing from pitman arm without disturbing anything else?
Thanks for any help.
60 years of golf,never a hole in one.
Under steering gear removal in the shop manual the first thing it states is "with the mast jacket removed"........
Barney Offline OP
I guess I was just trying to make it too easy.Thanks.
