Posts: 191 |
My original '32 headlight switch is beginning to blow fuses. I have an aftermarket switch, but would rather stay original. Filling Station doesn't show any original style replacements. Does anyone make an original style replacement?
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
I doubt that the switch is the problem.
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
As chevy b said probably not your problem but if it is I do have some nos delco remy switches.
Send me a pm if needed.
Does anyone make an original style replacement? No. However, as the others have stated, it is not your switch causing the problem. You probably have a short in the wiring that goes either to the headlights or to the dimmer switch.
Posts: 18 |
Had the same problem on my 31.....found a bare wire at the brake light switch. Look for a shorted wire.
