Posts: 766 Likes: 1
Posts: 766 Likes: 1 |
Hey!! :-)
No - the '48 is definitely not coming to the Central Meet. At the moment it's even looking iffy for the 6 Cylinder Tour.
Dale Carter VCCA #8661 1948 Fleetmaster Convertible 1948 RHD Stylemaster Sedan Delivery 1948 1-Ton Tow Truck 1967 Camaro Coupe
Posts: 2,037 Likes: 5
Posts: 2,037 Likes: 5 |
to decarter: What do you mean that the 6 cylinder tour if iffy? It WILL be ready. Just talk to your mechanic and feed him DQ Blizzards.
dtm
Posts: 1,623 |
Did he just say "feed him to the buzzards?"
Chevy Guru
Posts: 3,511 Likes: 47
Posts: 3,511 Likes: 47 |
Posts: 766 Likes: 1
Well, we started yesterday with high hopes! Cousin Dave came up to spend the day as we had everything back from the machine shop and were ready to assemble this engine!! We first put the crankshaft in and the front engine plate. Then we went to put the camshaft in, but it didn't seem to fit. Even after hitting it repeatedly with a 10 pound sledgehammer we couldn't get it into the engine (just kidding). So, we took it back to the machine shop. Oh yeah, he says. Cams never fit in. Probably need to line bore out the cam bearings. Seems like something he might have mentioned earlier - like I installed the cam bearings like you asked, but your cam won't fit. With my very limited experience with new cam bearings, in the past the cams have always slipped right in. So we're waiting for him to fit the camshaft. Meanwhile, the 6 Cylinder Tour is creeping up on me...
Posts: 3,578 |
Why is it,those we pay are the last we can trust???
Posts: 766 Likes: 1
Posts: 766 Likes: 1
Guess I have to post twice to get all the pictures to load.
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
Posts: 3,578 |
Dale you are definitely the winner of the great engine re-build race!!!We should also file those pics for the perfectly correct blue-gray paint....Great looking job, my friend!!!
When I had my 216 done, it took the guy a year
Is that the extra high heat paint 1200-1800 deg. on your exhaust manifold and tranny?
The 48 engine has been a typical engine rebuild except for one or 2 glitches. The distributor driven gear is an extremely tight fit with the camshaft drive gear. Maybe a burr or other interference issue on the brand new NORS camshaft? dtm ps. Cousin Dale was kidding about watching General Hospital in the afternoon. We quit for 2 hours to watch Judge Judy.
He could have gotten done much sooner if he wouldn't have called me every five minutes for advise.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Did Dale restore that ol' convertible and neglected to do the engine? Mercy! Dale: a. Did you use a fiber cam or an aluminum one? b. Did you install the dippers in the right direction? When the engine is upside down it makes everything seem to rotate backwards. Now that you have it all buttoned up, what do you think? c. You are luck to have help. I hope you installed the shifter on the transmission before installing the assembly. Won't matter until you try to hook up the vacuum stuff. d. What are you going to use as a break-in oil? e. The color sure does look dark. Must be the photographer's fault. Was that from the FS? Good luck with it, Charlie
Question. If you live in Australia do the dippers face the other way? And if the oiling system is working correctly the fiber timing gear will last for over 100,000 miles in a 216 engine. Dale rebuilds his engines every few thousand miles.
Posts: 117 |
Question. If you live in Australia do the dippers face the other way? Our dippers are in the valve cover, the rocker gear is in the sump.
Good thing I am wearing my VCCA regulation hip boots. It sure is getting deep here. Dean
Posts: 885 |
That sure is a thing of beauty Dale!! -- Not you of course, the eng and car!!
Jim
OK, it is Thursday, is it in?????? Running???? Can hardly wait for more pictures!!!! Much good luck. Skip Judge Judy and stay with it!
Posts: 766 Likes: 1
Just wondering? Why did you decide to treat the intake manifold the way you did?
The intake and exhaust manifolds were bolted to the engine when the engine was painted. The manifolds and attaching parts were all "engine color".
Posts: 766 Likes: 1
And we all know how long that engine paint lasts on an exhaust manifold!! I had the exhaust manifold ceramic coated. Intake is just painted to closely look like the exhaust manifold. Hoping the exhaust manifold stays decent for a while.
Posts: 766 Likes: 1
But of greater importance, here in Ohio at about 1:30 PM, EDT, we officially threw in the towel on trying to get this engine ready for next week's tour. We've decided this "interference" fit we have with the distributor and camshaft can only lead to bad things like metal in the engine and so we've decided to pull the camshaft and sort out what's going on. Unfortunately, with the engine in the car, that's going to involve removing a lot of stuff to get access to the camshaft. Who would have thought we needed to trial fit a distributor while it was on the engine stand...
Posts: 293 Likes: 2
Posts: 293 Likes: 2 |
Dale
"Just asking" Did you try another distributor to see if you get the same kind of interference. I've been messing with these old six cylinder engines since the early 50s and never encountered that sort of problem. I've ran 216 distributors in 235s and vice versa without any sort of interference with the cam gear. Its a PITA to pull that cam out in the car.
Dang, I am so sorry! Don't know what else to say.
