Posts: 129 |
can someone please post some pictures of original skirts? mostly interested in seeing the inside mounting features/construction.
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
Chevs of the 40s sells the skirts. The might be able to help you.
Joined VCCA June 1, 1961
Posts: 327 |
If the '40 skirts are very similar in construction as the '38, I can take pictures of my originals at different angles for you.
Someone else will have to chime in about that though.
~Jim
'38 Master Deluxe 2-Dr
*Disclaimer*...All technical advice given is for entertainment value only, and is not to be taken seriously...
The 1940 skirts are very different from the 1938. They are a one year only plain tear drop skirt. Attach with levers on the back I don't have pictures but some were posted a year or so ago.
Posts: 129 |
I searched for the thread for the pictures but came up empty. do you know which thread or if anyone out there has originals to post?????
You could contact the 1940 TA....info. in the G&D.
Posts: 19 |
I've got an original set. PM me an email address and I'll send you some pics.
Posts: 929 |
Someone else will have to chime in about that though. Jim, I have a 38 and would appreciate pictures of the different angles of the inside of your skirts. I will be buying some after markets that supposedly need to be modified to fit better and be more secure. Thank you Mike A
Posts: 490 Likes: 3
Posts: 490 Likes: 3 |
Hi, found this Picture
Posts: 929 |
Posts: 490 Likes: 3
two more pics
That is NOT a 1940 fender skirt. Note the big flange on the bottom. That is a common aftermarket skirt sold in the '50's.
They also look like they are straight/flat and not bowed like the originals.
Posts: 293 Likes: 2
Posts: 293 Likes: 2 |
Chevgene will probably correct me but I don't believe I've ever seen a "real" set of '40 fender skirts and I would be skeptical of anyone that sez they have original '40 skirts. I was going to high school in the late '40s and early '50s and you saw tear drop skirts on all makes of cars from mid '30s to '48. The "flared" skirts shown above were the cock of the walk back then and highly desired by those that wanted fender skirts. I do not remember ever seeing anything but tear drop skirts back then unless it was a Buick, Packard or Cadillac, etc. None of the fancy skirts I see on the different models of Chevs on this site were seen. People just didn't buy stuff like that for their cars back then. I remember buying a brand new set of "flared" tear drop skirts for my '40 F--d from Western Auto for $12 and my Dad raising cain because I had wasted money on useless items (we were farmers).
I currently have a set of tear drop (not flared) skirts on my '40 and they are attached with a clamp and wing nut bolt at the front and back lower edges. The clamp in the upper middle is closed with a lever and I have no idea of the brand. The skirts were purchased at a festival in a small Ark. town. They fit the profile of the rear fenders well but I seriously doubt if they are anything but after market.
I completely agree with the above. I had such a pair of skirts on my '41. Chevrolet never sold a skirt that was attached with winged nuts. Also the correct 1940 skirt had a pull down lever with two rods in v formation running up to the wheel opening and little brackets that were fastened onto the lower front and rear of the wheel opening for the skirt to hook into. I can say I do not recall of seeing a 1940 skirt also.
Posts: 327 |
Jim, I have a 38 and would appreciate pictures of the different angles of the inside of your skirts. I will be buying some after markets that supposedly need to be modified to fit better and be more secure. Thank you Mike A Mike: As soon as I have a chance to even step into my garage, will take pics and start a new thread so we don't hijack this one. Should be able to do it later this week. Jim
~Jim
