#333604 02/06/15 09:12 PM
Chevx2 Offline OP
Hi all, Could someone identify this horn is it 6v or 12v, it is working but sounds terrible, is their any adjustment. Also there is a black resistor (I think thats what it is , is there a replacement for this as the one in there is no good.)Hopefully photos work.:)
[Linked Image from ]
no pictures on my end
David Martin-Hendersonville NC, Pine Island Fl....... 1940 Chevy SDSS,
Chevx2 Offline OP
Martinomon thanks just trying to sort out the photo issue thanks
Chevx2 Offline OP
someone here will know what that is .....sorry ..not me
Looks like a 1937 to 1939 6 volt Chev horn.
After they sit awhile they can use an adjustment...Remove the cover ( if it doesn't have a screw and lock nut on the outside )
And you'll see it...Should say if it's 6 or 12 v...Hook up a power supply and turn the screw till it sounds good...Earplugs recommended...
