Posts: 75 |
Are 1923,1924,1925 and 1926 radiators inner changeable? Thanks
Posts: 1,049 |
if it fits in the shroud you are probably good to go here is a link to someone who sell them http://www.thebrassworks.net/shop/index.php?cPath=10_5815 to 22, 23-24, 25-26, 27, 28, 29-30, 30, 31, 32
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Posts: 11 |
They are not interchangeable. '25 and earlier have the bottom inlet on the left side. "26 and later are on the right side. When they changed to the belt driven generator, the inlet was moved to the right side.
Posts: 75 |
Thanks for the info. On the brass works website, the radiator I have is exactly the same as the 24 superior. The reason I wanted to know is someone is in need of one in the parts wanted section for a 1925. The one I have is from a car which was restored and the barn it was stored in collapsed on the vehicle destroying it. The owner passed and his son in law stated it was from a 1924 and sold the parts he could salvage. The radiator is as good or better, than the one on brass works. The inlet is on the left side if sitting in the vehicle. He must of had it professionally rebuilt because the solder is still shiny. According to brass works the 1925 is different.
Posts: 324 |
22 and older are 490 models and they differ significantly from the Superior. 23 and 24 Superior radiators are unique to those years. Although the superior was built from 23-26, the 25 and 26 models has many changes including radiator size and shape. R/Tom
