Posts: 1,411 Likes: 7
Posts: 1,411 Likes: 7 |
I've gone through the shop manual without finding the fuse info needed. In getting ready for a tour next month I want to verify the fuses installed now are correctly sized. Can someone post a list of the correct amp sizes needed for all the buss ports in the BelAir fuse block or point me to an info source? I am uncertain the PO used the correct ones. In correcting a couple of minor wiring issues it appears they took shortcuts that could have resulted in excitement best avoided. Thanks in advance.
Go to Old online Chev. manuals. Find 1955 owners manual. See page27.
Thanks Gene, between that info and archived posts in another website, I found the info needed. Finding the correct fuses was another challenge. Apparently, some sizes in glass fuses are a special order item these days.
