ok, here we go. this has probably been asked before but I can't find the answer. in 1966 chevy had two frame stands. 6cyl and 8 cyl. two different motor mounts, short and wide, tall and narrow. the tall and narrow will not go over the frame stands. the question is, if you have a big block, do you use the short and wide, whitch will work. the short and wide was for the small block. again, do you use the small block mounts in conjunction with the cable in case the mount breaks? I can't understand why chevy says to use tall and narrow when they won't go on the motor stands. any ideas? belair b body
