Posts: 105 |
Engine Casting Number 3555418 is (hopefully) a 1933 Model Year Number, is it not? Not sure if you'll be able to decipher what plant it was cast in? Thanks much, EH!
'33 MASTER PARTS WANTED ~ ESPECIALLY SHEET METAL! RADIOS & "TRINKETS; TOO.
Posts: 1,919 |
The casting number will be 6 numbers on the right side by the fuel pump. It will look something like this:
836XXX B 20 3 Bow-tie
