I went to remove the instrument cluster cover for the 41 project. I wanted to get the chrome redone and then send on to have the color matched along with all the other things associated to the base dash color.
Well, I pryed up the square end where it was bent over and tried to slide it out, Stuck. Tried WD-40. Tapped it with a hammer. Broke the glass. Tossed it. Gave up.
See parts wanted.
a. So how do you guys get that dang stinkin' cover off?
b. What color is the hood release bracket under the dash? Brown like the air conditioning vent and the parking brake handles or tan like the base dash color?
Any help and/or advice will be much appreciated.
Charlie
BTW: I finally got the steering mast off. Just had to overcome the tight fit of the steering shaft. Knocked the horne/bushing with the worm end of another steering shaft. Now is that using your head or not?
