Posts: 136 |
Tried to start the 1929 engine yesterday. Pored gas into the temporary gas tank and the gas pored out the fuel pump. I made a new gasket and pored gas into tank and it pored out bottom of carburetor. I made a gasket and will see today. Two problems that I need to look at. One-- Battery negative cable is getting smoking hot when trying to start. Two--- It didn't seem like I was getting spark from the coil. Steven
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Clean the terminals on the battery cables. If clean then replace with a larger (at least 2 ga. 00 is better). If battery terminals or cables are more that just a tad bit warm then replace them. Resistance causes heat and lower starting voltage.
Posts: 136 |
So I changed the negative battery cable and that has stopped the heat up on that. Carburetor is not leaking but small leak in fuel pump still there. I think I can fix that. Still no spark but I am getting 6 volts to the coil and then 6 volts out. But no spark out of distributor. I have been told to check the ignition to distributor connection to see if I am grounding out. The Coil is now getting real hot.. Why is that??? Steven
Posts: 301 |
Are you using a 6 or 12 volt battery?
"Never give up" Louis Chevrolet
If the distributor is shorted, welded together points, or any other short on the engine side of the coil will make the coil hot(er).
Posts: 136 |
Yes it is a 6 volt and I have a original ignition. I thought that I had all the insulators in place but I will look again. Anny advice for that? Steven
Posts: 136 |
So I did have a ground in the distributor. Got that fixed and tried to start again. Coil did not heat up I think I saw a spark this time. I did readjust the points. Then the starter started to smoke. Man one thing after another. By the way I think the leak in the fuel pump is fixed. Steven
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
How long did you crank it before the starter started to smoke? If it was a short time I would check out the starter for problems. If you cranked a long time I would let it cool and prime the engine by putting a small amount of gas down the carburetor and try it again. If the engine is tight and you cranked a long time it could have over heated the starter.
Ed
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
If you are gravity feeding the carb and gas leaked out when filling the gas supply tank it sounds as though the needle valve/float may be stuck open. Also it may help to prime the oil supply by removing the distributor and turning the oil pump with a drill and a slotted drive tip. This will help to prevent a dry start up and also may help it to turn over easier. I would be very concerned with the gas leak at the carb as it could lead to a fire.
Posts: 136 |
So I placed a different starter in and it had twice the power. I am looking into rebuilding my starter now. I ll let you know when I can. Steven
