#268238 01/22/13 02:34 PM
Over eighty years worth of crud and corruption encrusted my thirty-one's cowl data plate. Cleaning it became tiresome and tedious. I hit upon the idea of oven cleaner. An application of oven cleaner, an overnight soak and scrub with a toothbrush under hot water made it clean as a whistle.
Best Regards,
Tom
Good tip! Thanks for trying it and reporting on the results.
Was there any paint on the plate or was it just stamped information? I would be afraid that the oven cleaner would take off any paint that was on the plate.
I would have soaked the aluminum firewall plate in lacquer thinners and used a soft brass brush to clean the surface.
I would have thought the oven cleaner might attack and eat the plate but obviously not....good tip.
mike parking
I tried it first on a piece of scrap aluminum to ascertain no damage would ensue. Likely it would remove paint so I'd probably not try it on a painted surface. It was stamped not painted.
Tom
Great suggestion. I have the same problem on my 31 cab. The last restoration about 25 years ago painted the plate. I have to get it off, and your suggestion sounds like just the trick.
Thanks for sharing.
_________________
Perry A. Seaton
pseaton@kc.rr.com
Oven cleaner does a great job on grease and old dead paint but rarely will remove good paint.
Al
