Posts: 15 |
Hey guys, Im restoring a 29 cabriolet. The car wasn't complete & I am missing the link bars inside the top which lock the tops side rails, over the window, tight against the door jamb vertical. I would like to find an owner of a cabriolet who would be willing to email me a picture of what these parts look like so I can try to fabricate them. Anyone out there know a cabriolet owner?
Posts: 92 |
Have you tried the FillingStation and/or I&I Reproductions, Inc. They may have the "T" bolts. Probably cheaper and would be chromed.
I have a 31 Cabriolet, but it is in storage for the winter.
_________________ Perry A. Seaton pseaton@kc.rr.com
Posts: 17 |
I have a 29 cabriolet email me a picture of the area on yours that you need and i will take a picture of mine and email it back to you. email to rbraunh@aol.com thanks Bob
Posts: 1,919 |
You do know a 28 Cabriolet is the same as a 29 in the top area? I think I know where you will be able to get the parts you need. They will be SS castings. A friend is working on a 28 and needed the same parts.
Posts: 68 |
Hi: I have a 29 cabriolet and I have fabricated those support arms from brass.I have an additional set of them ,1 set chromed and 1 set not.I am a Canadian wintering in Florida,and they are in Canada.I also have made sets of Landau arm prop nut clips,part #4280184,for the outside arms,from polished stainless steel if you are interested.Send me a reply if interested,as I can tell you most things on a 29.
chevnut
Any possibility of a picture of the Landau arm prop nut clips? I have a 28 Convertible Sport cabriolet and may need it. Check my stuff for email if needed
Posts: 15 |
Thanks for the offer but my top is all disassembled & being repaired & painted right now. I have the hardware out to be plated. I will try to find an old pic that shows the area. It is the inside upper corner of the side glass. The top has a pivot point on the upper corner and another on the b pillar at the rear of the window opening. There is a missing link between those points.
Posts: 15 |
Yes I am interested in a set of those bars & nuts. When are you going to be back in Canada?
Posts: 15 |
Yes stovebolt2 I have several questions and would like to speak to you. E-mail me at harper71@bellsouth.net & we can xchange ph.#s Thanks Larry
Posts: 242 Likes: 1
Posts: 242 Likes: 1 |
all the casting are available from Verdones Classic castings verdones@evenlink.com Jere and Marge Verdone in PA and the clips are available from Antique Auto Top Hardware in Molalla OR Kim Dawson 503 824 5888 . Jim
Jim
Posts: 15 |
Hey I just wondered if you could email me with your friends # that has the top iron castings. Thanks harper71@bellsouth.net
Posts: 15 |
Thanks Jim, I will ck it out.
Posts: 15 |
Hello again, I am still trying to find those curved bars on the inside of my 29 cabriolet. Can you hook me up with your friend who has the ss ones . Also I can use some pics of the rumble seat area where the rumble seat bumpers go and the rumble latch itself which is missing on my car.
Posts: 1,919 |
AntiqueMechanic is the guy that can help you. Look at his posting above.
Posts: 68 |
Hi:I can help with all you need but I'm a Canadian wintering in Florida.I'll be home in April if you'r interested.I have inner arms,and info on rumble lid stops,any measurements you might need and prop nut locks.Let me know.
chevnut
Posts: 15 |
Hello again, I think I have found a set of the inner curved bars for my cabriolet but I do still need one of the pivot attachments & the special shouldered bolt that attaches the bar to the top. Also pics of the weatherstriping at the top & rear of the door glass. I also don't have the wood trim for the b-pillar on the top. Any info or pics wood help me greatly. Thanks.
