I replaced my generator with a 6 volt 60 amp alternator about 10 years ago. I was advised to attach a 4" piece of 10 ga wire between the 2 screws behind the ammeter. Any current above the limit of the stock ammeter would pass through the shunt and not damage the old ammeter. The ammeter reading is reduced by about 10% but works fine and no need to worry about damage in the event of exceeding the 20 or 30 amp ammeter. I got this from an old shop manuel printed, I believe,in the 40's. Very simple to do even for me!!
