Firstly, I want to thank all those who have replied and provided valuable input into previous questions I've posted about rebuilding the engine on a 1936. I haven't been keeping up with the forum regularly, but will try to do better in the futre and find time to help out where I can on this forum.
Now to the question: I'm going to drop the oil pan to check the connecting rod clearances on the 1936 over the Christmas holidays. While it's off, I would like to find a way to check the tubes in the oil pan for correct aiming at the connecting rod dippers.
There is the special tool for this purpose as illustrated and described in the Shop Manual for the 207. So, the questions are:
Would anyone have one of those tools/templates and be willing to rent temporarily? If so, would it be ok to try copying the tool--it seems basically be a flat piece of steel with perforations and a few bends.
Or, barring locating one of these tools, is there another way to check the aiming of the oil tubes?
Is this step considered crucial when rebuilting an engine? One factor is that the oil pan I'm using was not original to the block currently in the car. So would having an oil pan/block combination not mated at the factory be an issue with oil tube aiming? I've already used the grease method to check the depth of the dippers.
Thanks!
