I found a 22 490 and am puzzled by the fact that the front and rear widths are different! Not the frame!I know it is wider in the rear.
The front is wider than the rear? (Axle hub to axle hub)
Why?
The guy wants rid of the pile!
It consist of complete chasis, cowl, window and frame, and radiator. Other parts are included such as complete dash and instruments. The wood wheels are tight and was converted from a 4 door to a ranch PU. It has two good doors with panels and rear seat section. He only wants $500.00.
I like it a lot except for the different widths.
The wheel base is correct!
Any ideas on widths and also input on his price??
