1937 coupe-The front door window sits in a channel and the channel rests on a mechanism that raises the window up and down. One end of this mechanism is tight against the channel the window sits in the other is a little lower-on an angle. Does the part that fits against the window channel go toward the front of the car or the rear? Or in other words, how do you tell the right from the left?
Thanks,
Annette
