Steve from the Filling Station here. I would like to answer a couple questions so others don't get confused. First off, the water pumps we had made were a 3 year project. Lots of testing, changes and improvements took place in that period and we are very happy to offer this high quality, maintenance-free water pump for the early Chevy Sixes.
The color - it was not possible to get a factory (that makes 60,000 water pumps per week) to mix a special color for our 500 water pump order. They just flat refused. It takes about 5 minutes to mask off the brass nut and impeller shaft and spray the rest of the pump. Not a terrible amount of work or inconvenience.
The gasket - every water pump comes with a gasket. Look carefully in the box as it may be on the bottom. If you find that yours did not come with a gasket (stuff happens), just call us and we will send one to you at no charge.
We are pleased to bring this great upgrade to our customers and look forward to seeing many of you driving your old Chevy with one of our new pumps installed.
