#252554 08/18/12 10:21 PM
I'm looking at purchasing a NOS fuel pump. What would you experts think regarding the diaphragm and other internal parts as needing to be replaced?
1934 Three Window Coupe
[img]http://www.youngsdecks.com/YoungsDecks/1934_Chevy.html[/img]
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Yes, yes, yes.
My personal experience is that any fuel pump that is older than 1980-ish suffers from a fairly quick failure rate.
The failure? THE RUBBER DIAPHRAGM. It turns to goo within a week or so.
The reason? THE NEWER GASOLINE ADDITIVES - IN PARTICULAR ETHANOL.
So, my suggestion is to buy the pump, but DEFINITELY replace the diaphragm with a new rebuild kit that contains the newer rubber.
Youngfalcon
As Bill suggested replace any rubber part before fitting or you will do the job again in a short period of time.
It does ruin the "NOS" part of the deal but I would consider that a very unimportant point.
