Posts: 165 |
The splines are stripped on my door handle regulator . If I apply pressure on the handle It will operate the door , but is starting to spin on the splines. Not good... What are my options. It's too bad the handle doesn't have a small screw in the center, Like the seat crank handle. Stanman
earlychevguy
Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
If you go to this page, then click on the left side, it will take you to their site. If you click on the right side, it goes to their catalog. I'll let you figure out where the center click takes you. http://vcca.org/advertiser-index.htm
Posts: 165 |
I have the catalog. Just trying to see if what I have is fixable. Stanman
earlychevguy
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Some have drilled the handle and regulator for a pin. However that weakens both parts and it may work for a while if you treat it real gentle, but as JYD says get a new handle. It will save you from repairing or replacing the regulator .
Posts: 165 |
The handle is o. K. It's the splines on the regulator that are bad.
earlychevguy
