#229831 01/06/12 10:16 PM
kevin47 Offline OP
My '47 came with a S.W. Temp. Gauge added below the dash...I suspect the original doesn't work...Question was : Can the Gauge be repair or do I look for one on Ebay...?
kevin47 #229836 01/06/12 11:24 PM
This has been covered a few times on the forum.
Yes, it can be repaired. Check in G&D for services offered for a source.
devil Agrin
kevin47 Offline OP
Thanks Ray...I want to remove that gauge 'cause it's mounted where the heater/defroster/etc. switch's belong...can't work around that...! Kevin
kevin47 #229871 01/07/12 11:42 AM
ken48
VCCA 42589
ken48 #229876 01/07/12 12:08 PM
kevin47 Offline OP
Thanks Ken...just what I was looking for...! I tried a search last night...Can't get that search thing to "work" for me...Kevin
WinoWally...First I've heard of him...Doesn't live far away ...Hope he doesn't run in to me . lol
I was kinda hopping I could get tips on how to fix it myself...I like to tinker and get a better understanding of things Chevy , etc . Thanks Again
kevin47 #230941 01/15/12 01:34 AM
To repair the temp gage it takes special equipment. This tells you about the mechanical gage. Some are filled with eather.
http://www.secondchancegarage.com/public/653.cfm
kevin47 Offline OP
Thanks Keith...I can always rely on you...Picked up Two Complete Dash Gauge Clusters last week on Ebay ( just for the Heck of it )...Haven't actually tested the one in my car...It came with a S&W Temp. gauge attached below the dash and it's going to interfere with the switchs I need to install ( heat / defrost ) Thanks for the Information...Kevin
kevin47 #230987 01/15/12 02:43 PM
You can repair the temp gauge your self with just a soldering iron or gun and some ice.
there is a good info on the mopar web site if you do not find it contact me and I will give full instructions.
DO NOT USE A FLAME TO SOLDER A TEMP GAUGE.
AL
a3alf #231010 01/15/12 05:39 PM
kevin47 Offline OP
...But I'm a Welder...Must use blow torch...did I tell you about the "Fire"...?...Just Kidding...Guessing there' a "bourdon tube" involved...? Oxy / Ace Gas Welding Regulators use that same principle , too...I'll check out the Mopar site....Thanks , Kevin
