Posts: 9 |
Would anyone happen to know where I could find an engine crank for a 1928 Chevy 2 door sedan in decent condition? Doug
Posts: 597 |
I have seen them on occasion on eBay
It's not how fast you can go, but how good you look at 20 MPH.
Posts: 61 |
I have one, it seems to be fine, I had two engines and had one rebuilt, this is just extra.
Posts: 809 |
Gregg Just remember the 28 has a longer shaft than the early ones Chris
Posts: 9 |
Gregg: If you're willing to let it go, how much are you asking? Do you a photo you could include? Doug
Posts: 61 |
I'm not at my home right now, but as soon as I am I will take a photo. I'm not sure of it's value,what is the offer? I will need to find out about shipping also.
Posts: 11 |
Doug, I subscribe to a paper out of Lancaster PA. and listed this week is a 1928 engine and radiator core for sale. No price was given but it is located in Cecil County, MD. phone # is 410-3984138. Worth a phone call. Clint
Posts: 61 |
Posts: 320 |
Are you after a Crank handle or a crank Shaft? You can make a crank Handle if you have an Oxy, the dimensions are front enf to first bend 11.5"( 23mm) length of crank 6.350" (162mm) length of handle 5" (127mm) all measurements are Centre to centre of the bends, RAY
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Are you after a Crank handle or a crank Shaft? You can make a crank Handle if you have an Oxy, the dimensions are front enf to first bend 11.5"( 23mm) length of crank 6.350" (162mm) length of handle 5" (127mm) all measurements are Centre to centre of the bends, RAY 11.5" is equal to 29.21 cm (292 mm) not 23mm as above.
JACK
Posts: 9 |
Thanks, Gregg. I'm not sure what the engine(starter)crank is worth myself. I saw one on ebay not long ago that looked like it had been dug out the ground. I think that one sold for around $25. My '28 has an electric starter, but a mechanic friend says a crank is great to have when working on the engine. Doug
Posts: 9 |
Thanks for the suggestion. It could be worth a shot. Doug
Posts: 61 |
Doug, I thought you were talking about a crankshaft, not a crank to turn over the engine. I don't have one of those. I apologize, I will look around and let you know if I can find one. Sorry for the misunderstanding. Gregg
Posts: 9 |
No worries. Sorry for the confusion. Doug
Posts: 596 |
I saw a "universal" crank at The Filling Station for $45
Richard Waverly, IA
