My A/C only blows on high so i need to change the resistor. Where is the resistor located? Please help. Any pictures would be helpful. I have changed the relay and switch.
Wilwood Engineering1955-1957
the a/c resistor is probably located in the a/c air duct downstream of the evaporator. that's where it's located in a '76 nova and i think most all cars. i can send a pic if necessary.
Contrary to the rumors, I'm making great progress on the bulb. So far I have found 169 things that won't work.---Thomas Edison.
