hi i want to buy 15 anniversary pins can i get them in flint as i dont have dans email address i can not order them in time from Australia before the event. where or when do i get my confrmitaion pack from for the event
Liz
Hi, Liz -
I will send a copy of your posting here to Dan, I'm sure he can help you out with this.
I will also send it to Meet Chaor Dave Miner. I know that the confirmations were just mailed on Monday past.
See you in Flint!
Chevy Guru
Hello everyone:
All Confirmation Letters for the 50th Anniversary Meet were mailed on Monday 6-13-11 by US Postal System First Class Mail. The only problems that I see is with the postal issue/strike that currently exists in Canada.
The letter gives Exact times for each and every tour that you signed up for. If you registered prior to 6-1-11, you should be included in every tour that was offered. We might have had to tweak the times a little bit due to some tours selling out. For example, as of 6-17-11, the following tours are closed:
ALL GM Proving Ground Tours on Friday 7-22-11 are closed
The GM Proving Ground Tours on Tuesday at 7:15-10:45am and from 1:15-4:45pm on 7-19-11 are closed.
Saginaw Street Car Show on Thursday is closed - window clings have been ordered
Car Judging / HPOCF / CDPC is closed. The layout of the fields asre currently being developed for the 509 vehicles that will be there has begun. Also the engraving trophies has begun.
ALL GM Heritage Center Bus Tours on Monday 7-18-11 are closed. You are still encouraged to drive to the Heritage Center on Monday in a private vehicle or to sign up for the bus on Tuesday 7-19-11.
dtm
the toolman
VCCA # L 28873
Hello everyone: The GM Proving Ground tour on Tuesday Morning at 8:45am is closed. You can still sign up for the Tuesday GM Proving Ground Tour leaving at 10:15am and 11:45am.
dtm
the toolman
VCCA # L 28873
thanks for your help
we are looking forward to flint
