#207515 05/22/11 08:40 PM
I'm having trouble with the foot operated starter on my '47 fleetline. It seems like the lever isn't going in far enough to push the button on the starter. Anyone have this type of issue before?
47 Aerosedan
41 Cabriolet
Fleetboy #207557 05/23/11 07:54 AM
Check for wear in the linkages. There may be an adjustment at the starter and the contacts inside the starter may be burnt down.
Fleetboy #207916 05/26/11 08:51 AM
If you remove the switch from the top of the starter, you may find that the contacts are burned and worn.
Fleetboy #208035 05/27/11 08:44 AM
I replaced the switch on the starter of my '42 recently for the same problem. It works great now.
Cleon
Cleon Eck #208041 05/27/11 09:20 AM
Usually when the switch contacts wear, the contact/post on the starter wears as well. Putting a new switch on will be a quick fix, but it's life will be shortened due to the fact that the field coil post is still wore. I always replace the post when putting on a new switch, so you have all new contact surfaces. Unfortunately, it's not the easiest repair in your garage. It's a fairly involved repair compared to changing out a switch, unless you've done it before and are set up for it. Anyway, just my 2 cents.
Jason
Advanced Electrical Rebuilders
jason@aerrebuild.com
www.aerrebuild.com
Specialist in Starter, Generator, Distributor & D.C. Motor Restoration
Those are some great tips, thanks guys!
47 Aerosedan
41 Cabriolet
