badboy Offline OP
I am trying to remove the s/s mouldings around the out side of my car. I was told there were screws inside the interior, so I removed the trim inside and I removed about three screws, that had flat bottoms as if to hold something from moving. That didn't work. I cut all rubber seals that go around the window. Does anyone know how these front mouldings are removed. I took the back mouldings off the rear window, there were clips on them. I don't seem to see clips on the front. Help is appreciated!
Wilwood Engineering1955-1957
Hi Badboy,
There are no clips on the front w/shield moldings.
The w/shield must be removed from the body.
Then remove the glass from the w/strip.
Then remove the moldings.
The moldings were installed in the rubber before the glass was installed.
Oliver J. Giorgi
1958 Passenger Car
badboy Offline OP
Thank you, myself and my old buddy who worked as a glaser, helped me remove the front and the back.
